Questions & Troubleshooting for ZBrush 4R4
I’m unable to control+click and drag anything. I can create a new menu after enabling customize but that’s about it. I tried using alt/option click and drag as well as command+click. Either of the combinations seem to work.
Ok, I’m an idiot…my brain must be fried…It’s been awhile since I customized my UI so I forgot you have to hold control+option to drag items. I’m going back to customize my UI and if I have any other problems I’ll be back.
It’s Alt+Ctrl+drag
To whom it may concern, 4r4 keeps asking me to activate it every time I launch it (after I shut down the computer and start it back up, but it won’t do so if I close 4r4 and restart it without shutting down). Please help, it’s getting annoying having to go get my activation key every time I launch 4r4 after starting up my computer (as if 4r4 forgets that I have already activated it).
I am using Windows 7, 4 gig ram, 650 Gig HD, Pentium ® Dual-Core CPU E5400 @ 2.70 GHz.
Darn, now I got the message below (of course):
What does it mean “this machine was never registered”? I never saw anything about having to register my machine. I just followed the instructions for installation and it worked like a charm the first time. Then, I shut down the computer, started it back up and 4r4 asked me to activate again until I hit the issue above. Anywho, please help!
have an issue with download link displayed after entering email/Serial N° which goes nowhere (xml error page : specifed key does not exist) ?
I’m having trouble downloading the 4r4 updater.
I clicked “Request Download Link”, filled in my e-mail address and serial number, and clicked “Generate Download Link”. I’m pretty sure both my e-mail address and serial number were entered correctly, because when I make an intentional mistake in any of the two, I get “the entered email address and serial number do not match”. But when I make no intentional mistake I get “Download ZBrush 4R4 Mac Edition - You have 3 days remaining to download”. So far so good, but when I click “Download ZBrush 4R4 Mac Edition”, I get the following error message page (I’ve retried a few times):
<Error>
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>187421/ZBrush_4R4_Installer-OSX.dmg</Key>
<RequestId>0926DE5F449E4AD9</RequestId>
<HostId>
R7ww/vWlDMes/rKLjabZO7kRzCbE37QL9bu+JZ+nTFXu7DLwkakPoG27dUTiT4Sv
</HostId>
</Error>
I’ll try to open a support ticket, I hope that works. And I hope 4R4 is worth the time and trouble I’m spending trying to get it. Unfortunately, I can’t tell, because I don’t get the “What’s new” guide without the download.
Maybe you could include a separate link to the “What’s new” guide, so we can see what’s in 4R4 without all the security hassle. Might be an idea. (Yes, I’m ranting a bit here.)
I’m using a MacBook Pro 17" from April 2011 with Mac OS X 10.7.4 Lion. (Not Mountain Lion.)
I was on the beta testing team for this release, and there were several instances when the program would crash in the blink of an eye, disappear like Kaiser Sosse.
Just, “Poof”. Gone with no hang time or spinning wheel of death, no premature termination warning.
Since the release of ZB4R4 I have had flash crashes while using lazy mouse, playing back movies, using dynamesh, merging subtools, opening layers on tools, opening layers on tools created in earlier versions of the software, saving with history and using Zspheres… well, a lot.
I am running Windows 7, 64 bit intel core2 quad 5.50 GHz, 8 gigs of ram, with 200 gigs of free space on scratch disc.
Bummed
I’m getting the same - never had an issue with any of the other updates. Hopefully it’s just a time out style issue.
the-look.jpgHi guys ,this is the look of my download link ,does anybody have similar problem ? this
happens when I press download Zbrush 4R4 Win edition button .
I am really inpatient to start playing with this amazing upgrade . This affects my quality week-end time
Same thing happened on my tablet ,so now I have on my both machines ZBrush deactivated ,versions 4R2 ,and I am unable to
download installer for ZBrush 4R4 with serial which was send to me via e-mail from Pixologic , on my work I got floating license so my ambitious plan was to check new upgrade before I have that installed on my machine at work , by this message i am getting looks like I am having wrong serial .
I’m seeing the old lightbox starts at program launch bug again even if its turned off in preferences. I tried all the default startup scripts here, and then best fix I could find was one that automatically shuts it back off after it opens on launch.
I did not see it start force opening at launch until after I created my custom UI.
hi I’m getting the same error and another. I followed the deactivate intstructions to the letter as well. Am now without my Zbrush!!
<Error>
<Key>187421/ZBrush_4R4_Installer_WIN.exe</Key>
<RequestId>8D2C97BA72F1E934</RequestId>
<HostId>
pKtAn7urNFtM6hEqhF/pFiJGvI68XSm5PWm7AZR+KLO034DbPJ1pyPKRiMJHb2o8
</HostId>
</Error>
and if I try to right click and download I get this
ZBrush_4r4_ installer_.exe
294 B no file
Ticket Submitted…
cheers
J
Unfortunately my position is the same as the last few posters I am receiving an XML error, I am guessing the server with the database containing the fields with the serial numbers is down>?
where all the image plane options gone?
never mind: I got it: in the draw pulldown
two-tone materials from lightbox-projects folder aren’t working as expected.
  • twotone_redapple
  • twotone_beetle
chem!
I’m getting the same XML error mentioned above.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<SCRIPT/>
<RequestId>20ABE108E97BB0C4</RequestId>
<HostId>
6CE3OHiO15JV5gnWiYMFD3rI//hmLfi53Dixy7N8lDnHmemlqnwMXmDG/B3iMyEG
</HostId>
</Error>
I have the same download link problem but in IE it tells me to install Java even though it is already installed. Then if I wait IE kicks it into compatibility mode and let me see the form fields. Is this a problem with java? Willing to try anything.
I got a download link error initially, and then just used chrome instead.
Im getting the same with chrome, Firefox and IE. have raised a ticket but any help would be appreciated.
I had that exact same problem with IE, so I used Firefox and it was OK.
I may have used firefox as well… I had all thre browsers opened at the time, and just popped the link into to the first alternate one after explorer that I could grab.
